When should timing belt be changed
At how many miles should belt be changed.
Hi there and not sure if you got your question already answered or even still need it to be answered :) What I seem to remember is that the M10 318 and 318 ('84-'87) has a chain, the M40 318 and 316 ('88-'91 & not many in the US) has a belt.
E36 = M50 = timing chain. E30 = M20 =timing belt
Although you did not specify the year, model, and engine size, here are some general guidelines:
All the 4 cylinder BMW 3-series (318i, 320i) had a timing chain.
From 1984 to 1991, the 6 cyl (325 series) had a timing belt.
From 1992 and up, the 6 cyl (323, 325, 328, 335 series) had a timing chain.
If the BMW you are inquiring about should have a timing belt, BMW recommends to change it every 60,000 miles.
Hope this helps a little.
+ Agreed
it is my understanding since having a honda (belt) and moving to a jeep (chain) I have been told about this kind of issue. If you have a timing belt and the timing belt goes you can crack the head or bend a couple of valves, so depending on the mileage, better to do it if you are not sure its been done. Otherwise unless your crazy lucky a valve job + new valve stem seals while you there etc etc....I don't know about much about BMW's but i think it's the same kind of deal.
the e30 320i had a timing belt and was a 6 cylinder m20 engine
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 4
Total : 6,772
