Aller au contenu principal
Deuxième génération de l'iPhone. Modèle A1241 / capacité de 8 ou 16 Go / coque arrière noire ou blanche. La réparation est plus simple que pour l'iPhone de première génération et nécessite des tournevis, des outils pour faire levier et une ventouse.
Questions au sujet de 1504 Voir tout
Really Philipps/phillips/philips PH00 screws instead of PH000?
Hej,
when I look at the screw in my iPhone 3G the size of the screws seems to differ a bit. The botton two are smaller than the inner ones, and the two holding the vibrator seem to be somewhere in between. I tried to unscrew them with a PH00 screw driver but it does not fit and I don't want to ruin the screw head. On your tutorial you describe all screws as PH00. Can you confirm that, please?
Cheers,
Uwe
Une réponse ! View the answer J'ai le même problème
Commentaires:
It would be helpful to correct the spelling to Phillips (two "l", one "p").
The name comes from the Phillips Screw Company, which patented the drive shape in the 1930s.
par
yeah, we all know this, but not all people that search for these sort of questions do, and we don't want to lose a good answer just because someone doesn't know there is a difference. We'll put it in the tags, then everyone is happy!
par
Ajouter un commentaire
Fix Kits pour batterie de MacBook
À partir de $69.99
Buy Now
À partir de $69.99
Buy Now
1 réponse
Solution retenue
I believe you are quiet right as the i fix it screw driver shipped was useless for me as well but a PH000 worked I had worked. Strange isn't it.
John
Cette réponse est utile ?
Score 1
Commentaires:
Thanks John,
after gets my hands on a PH00 and PH000 I can definitely say PH000 is the better choice.
par
My 3G uses a #000 phillips screw as well not the #00 in the bottom.
par
Ajoutez une réponse
Djui sera éternellement reconnaissant.
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 8
Total : 11,115
