Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Repair guides and support for C/K pickup trucks sold by General Motors under the GMC brand, including the GMC Sierra.
Locate vacuum hose by transmission
Locate vacuum line to transmission
Répondu ! Afficher la réponse J'ai le même problème
Indice 9
15 commentaires
Hello everyone I have a gmc 1500 4x4. I replace my trany and as doing so I don't know were the black rubber hoes connect to I do know that one go's to the transfer case and the other one gos to the tranmission but don't know were the other ends go to
And they both have plugsat the end of them I do remember are i think above the transmission there was a bracket they was connect to some please help me 28th pic
par
Same problem, tranny won't shift into third . 1989 Chevy Silverado. 4x4 5.7 motor . i need some kind advice on what i should do as far as do it myself or take it to shop.
par
@marciano68 You can start by checking the fluid levels in the trans when the truck is warmed up to normal operating temps.the trans fluid level is checked with the engine running in park . If its low it may be a good time to change the fluid and filter. If this brings no joy then you may need to seek professional help
par
Can u show me a picture of we're it goes
par
http://67-72chevytrucks.com/vboard/attac...
In this picture the line is steal but runs from the throttle body down to the tail of the trans. Its the silver line next to the trans dipstick tube
par
Voir 10 commentaires en plus
Ajouter un commentaire
2 Réponses
Solution retenue
The year range is pretty non specific.
If the truck has a vacuum hose to the transmission (to the vacuum modulator), the line will be a metal tube attached to the large tube that the transmission dipstick is in. It will come up and connect to a hose that will run to the base of the carburetor.
The function of this line and the modulator it goes to, is to give the transmission some sense of how much throttle is being applied during a shift to make the shifts softer or harder depending on load. The transmission will work without this line, but the shifts will be hard as if the throttle was all the way to the floor.
If the hose is broken or missing, there will also be a vacuum leak at the carburetor, causing a rough/high idle and possible an intermittent backfire.
If the truck is new enough, the transmission will be electronic and not have a vacuum modulator at all, and will have a plug with several wires connected to it on the drivers side.
Indice 15
16 commentaires:
i was wondering if the transmission has an overflow tube(rubber)cuz if not then i need to know where it goes. reverse is not working, but it will back up in 4 wheel drive low only when its cold. i put tranny fluid in yesterday nothing showing on the dip stick and it started leaking out that rubber tubing. the tubing in on top of the tranny itself. it s 700r4 in 1991 chevy truck 4x4. can u please help me?
par
where is the vaccum hose?
par
On a manual 3speed
par
I have a 1989 K 1500 and I have shifting problems to the truck was fine everything was fine with the truck it ships great and hoard it just won't ship until I get to a high RPM it's an automatic I've checked the vacuum of check the modulator I'm not sure if it could be the torque converter or what but it will not shift into 2nd until it gets to a certain speed and it won't shift into 3rd until a certain speed and by that time the motor is wound out
par
I'm having same issues with 93 c1500 I'm beginning to think its a defect with the transmission.
par
Voir 11 commentaires en plus
My old transmission that was in my 94 gmt-400 didn’t have the vacuum hose but my th350 does
Indice 0
Ajouter une réponse
bagwelltanya16 sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 49
30 derniers jours : 206
Total : 112,206
