Aller au contenu principal
Le Samsung Galaxy S3 est un smartphone multi-touch, au format ardoise, capable de suivi oculaire, au stockage accru et avec une option de recharge sans fil.
Questions au sujet de 494 Voir tout
Cracked screen. What part do I need?
So one day after school I took out my phone (Samsung Galaxy 3 i9300) and it had a big scratch across it lengthways, only one though. I do not know which part to replace! The touchscreen works completely fine, the display is perfect (except for the scratch of course) so what do I replace and how?
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Ajouter un commentaire
1 solution
Solution retenue
The lcd and touch screen are 1 part. you can either get the "Galaxy S III LCD Screen and Digitizer (no Midframe)" which requires a little more work by transferring some pieces from your current screen to the new one or get the "Galaxy S III LCD Screen and Digitizer" which includes the mid frame but cost a little more. The description of the "Galaxy S III LCD Screen and Digitizer (no Midframe)" in the iFixit parts store explains what it does and does not come with
Cette réponse a-t-elle été utile ?
Indice 1
Commentaires:
NO! That is just the glass. If you have to ask if that is the right part then you are not qualified to do the repair with just the glass. Repairing an iPhone for instance with just the glass requires heating up the screen enough to loosen the glue with out damaging the lcd or any other components, separating the glass from the lcd, and then using Liquid Optically Clear Adhesive (LOCA glue) and the cursing the glue with UV light. It is a Very difficult repair with a high failure rate.
Below are some of your choices. Keep in mind that which Cellular Carrier you have can make a difference.
Galaxy S III (AT&T/T-Mobile) Screen
Galaxy S III AMOLED and Digitizer
https://www.amazon.com/Generic-Display-D...
par
That Amazon link, does it have all the parts of the screen or do I have to transfer parts from my old screen?
par
It looks like you would have to transfer some parts.
par
@dp70737 - high failure rate? I've never had one of my repairs on this model fail. Maybe "you are not qualified to do the repair". Try not to be such a smug SOB, this is a learning site.
par
Voir 5 commentaires en plus
Ajouter une réponse
Adam sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 106
