Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
The Mac Pro First Generation is an Intel Xeon-based workstation computer manufactured by Apple Inc. The first generation model includes the machines from 2006 through 2008.
Questions au sujet de 316 Voir tout
Mac Pro Runs all Day and gets Hot
I have a Mac Pro with two additional 500GB 7200rpm SATA drives that are RAID1. That I believe is what is raising the temp. Is there a fan or other means that can be mounted inside the MacPro that can cool things off? Suggestions welcome.
Répondu ! View the answer J'ai le même problème
Ajouter un commentaire
Kits pour Nintendo Switch
A quick fix to get back in the game
Shop Switch Kits
Shop Switch Kits
2 solutions
Solution retenue
Hi!
I'd absolutely start by getting three cans of air, taking it outside, opening it up and blowing it out. Swap out cans as they get cold. You may need to leave the cans in the sun for a bit and start over.
Now we need to try to figure out why it's getting hot. Fire up your activity monitor (Applications -> Utilities) and watch what's going on with your CPU(s). You can click the "%CPU" to sort by what program is loading your computer. Something fun like SETI@home would cause your symptoms nicely.
Another thing you can try is watching your temp. sensors. The program I linked can show you everything that's being monitored by your computer. It might let you pinpoint what's making the heat.
If you think it's the two drives, turn your computer off after it's been on a couple hours, open it up and feel them. If they're too hot to touch, disconnect them and fire it back up for a while. See if the heat problems drop or not. If they're the culprit, get some firewire 800 enclosures for them. Since you're running RAID 1 you probably won't notice the speed hit and your drives will live longer. Yes, OS X will let you raid externals.
Good luck!
Cette réponse a-t-elle été utile ?
Score 1
Commentaires:
+ good
par
Here's
a place with RAM coolers
You could also try:
  • Dusting inside,
  • changing/customizing airflow (ducting heat away or cool air in - maybe using an external fan)
  • common sense (don't put it in a corner, up against an obstruction, near other heat sources, e.g. sunlight)
  • add a VGA fan cooler
  • Software to run fans longer or more often (runs the risk of burning out the fans)
If this answer was helpful please remember to mark it accepted.
Good Luck,
N
Ajouter une réponse
ki4tjy sera éternellement reconnaissant.
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 6
Total : 2,693
