Aller au contenu principal
Repair guides and support for smaller headsets that rest on top of the ear, also known as supra-aural headphones.
Questions au sujet de 438 Voir tout
Can I fix my severed cable?
Hi guys.
Today I managed to snap my headphone cable in half. The headphones in question are the B&O form 2i. Iv looked around the forum but my problem is unique as the cable has snapped exactly where the cable from the right and left speakers join into one cable.
How could I fix this? Please help.
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Ajouter un commentaire
1 solution
Solution retenue
First remove the little plastic piece where the connections split. Strip both ends of the wire, and on the end with the jack, use a multimeter on continuity mode to figure out which wire is left, right and ground. You may have to melt off some of the insulation first.
http://wiki.robotz.com/images/6/6c/Trrs-... (ignore the ipod video thing, it is irrelevant in your case.
On the end with the headphones, solder the ground wires from each ear to the ground of the jack, and left to left and right to right. Then test your wiring with this vid
https://www.youtube.com/watch?v=hTvJoYnp...
After you are finished, insulate the connections with electrical tape and hot glue it together.
Indice 1
Commentaires:
It all okay! I simply cut of the rubber insulation and joined the wires by simply twisting them around each other and insulating them with electric tape. I even managed to get the controls to work (the mic should work too but I have yet to test it).
par
Ajouter une réponse
Imad Knight sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 919
