Thin red line on TV screen
Hi,
I have samsung UA37D5000 tv. There is thin vertical red line appearing in TV. When I called up the local samsung service guys to check, they said they have to replace the panel and costs almost 23K. I don't believe in their words. Will you be able to tell if it's the real panel issue or some board issue.
If I have to open the TV, it would be helpful to have a teardown guide for my TV.
Attached the picture of the red line on the screen.
Thanks
Rajesh
19 commentaires
I have same issue
par karenggivens
karenggivens same TV? Same issues? If so then it is the same answer. TAB error.
par oldturkey03
I have 40" Samsung Curved LED TV. I have the same problem. Vertical line is approx one feet from left side and stationary. Please suggest.
par Siyaram Verma
I have the same problem. I check the tabs, applying pressure where the red vertical line originated but it did not solve the red line problem. What else could it be?
par brennan.moore99
so ii have to dismount the back from the tv ???
par AMD RX460 Gaming and Xbox
Voir 14 commentaires en plus
