Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Modèle mi-2009 A1278 / Processeur Core 2 Duo 2.26 ou 2.53 GHz EMC 2326
Questions au sujet de 941 Voir tout
Can I upgrade my logic board to a higher GHz?
Currently my 2.53 GHz logic board has a faulty ram slot. I have cleaned both slots and inserted and removed ram out of the bad one multiple times. Can I upgrade to a better Logic board? If so, what's my best option?
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Ajouter un commentaire
3 solutions
Solution retenue
First try backing the screws that hold the RAM slot mechanism off a quarter of a turn each and test again. Put a 4 GB in the working slot. The one that's not working will sometimes take a lessor stick.
You may be able to use this one, they are both A1278 boards, but I have not seen it listed as compatible.
MacBook Pro 13" Unibody (Mid 2010) 2.66 GHz Logic Board
Image MacBook Pro 13" Unibody (Mid 2010) 2.66 GHz Logic Board
Produit
$249.99
Cette réponse a-t-elle été utile ?
Indice 2
Commentaires:
I appreciate the help. I backed off the RAM slot mechanism screws a quarter turn which worked for 1-2 minutes but then the computer continued to shut down and restart. I will purchase this 2.66 GHz and hope that it works. Thanks
par
Ok, i did work. Try another quarter of a turn.
par
No point really. You could find one on eBay but it is not going to be a big improvement. Can you get the largest sized ram for just 1 slot?
Indice 0
would it be possible to replace the port? someone like luis rossman could possibly replace the port
here is his site:
https://www.rossmanngroup.com/
Indice 0
Ajouter une réponse
ethanmccrackenis sera éternellement reconnaissant.
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 96
