Not draining at the end of of the cycle
Dishwasher that is less than two years old does not drain at the end of the cycle. You can press the drain/cancel button and it will drain 50% of the time. I can hear the motor or pump running. We already replaced the control board, that was not the solution. No lines were clogged and the dishwasher does not run through the garbage disposal.
2 commentaires
I think I have the same problem you did. Did you figure it out?
par Danielle Venne
I have the same issue on my 2yr old Maytag dishwasher model MDB4949SKZ0.
The pump will not run at the end of the wash cycle. If I wait approximately 5 mins and press the cancel/drain button the pump runs and fully drains the dishwasher. Error F9 E1 which means didn’t drain or timed out.
par Chris
