tablet wont authenticate with my broadband
tab2 a7 wont connect to my broadband it keeps going authenticating to failed.broadband provider says a problem with my harddrive
it wont connect to internet.what can i do
Its most likely that you didn't type in the password right. Then there is the super simple answer: Are you sure you have wifi? What broadband provider do you use and what modem/gateway/router are you using?
with ee. wifi turned on and using ee router
well done josh you were right.i typed the wrong hyphon in.you are my hero
rule #1: Its always something simple until I'm proven wrong.
I also may have spent hours cussing out a new laptop that won't connect only to realize that I missed a digit on the password.
May be the problem is in the password? CapsLock was on or something like ths?
Did you check your wi-fi router or call your provider ? In order for the Internet to work well in the router, without failures, it is necessary that the fiber line is very stable. And this stability is very difficult to find. I also faced such a problem and searched for a long time for a provider that would provide a choice. And found, this is https://usave.co.uk/broadband/ . They have different packages with different speeds and different prices. After installation, everything worked very well. So I advise you to do the same. This is a good way out of the situation.
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 71
