Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Le Samsung Epic 4G Touch est la première version distribuée aux États-Unis du Galaxy S II de Samsung. Il est également connu sous le nom de Samsung Galaxy S II Epic 4G Touch.
Galaxy S2 turns on for a few seconds then turns off.
I have a Samsung Galaxy S2 Epic 4G, and the problem is that when I try to boot it on battery, it turns on for a few seconds, and then turns off. But it works fine when on charge. Do I need to get a new battery? Or is there something else wrong that I need to replace?
Répondu ! Afficher la réponse J'ai le même problème
Indice 1
Ajouter un commentaire
2 Réponses
Solution retenue
Daemeon,
Check the battery's physical appearance whether it swollen or not. if it is swollen just disposed the battery proper way & buy a new battery otherwise clean the battery terminals and charge the battery at least 15mins. hope you have good result :-)
Indice 2
Réponse la plus utile
I would definitely start off by getting a replacement battery. The symptoms you are describing point to most likely a faulty battery.
Indice 3
Ajouter une réponse
Daemeon sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 14
Total : 599
