Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Connu sous le nom de ''PS2'', c'est une console de jeux vidéo de sixième génération sortie par Sony au Japon en Mars 2000. Elle sera disponible plus tard aux États-Unis dans l'année avec la SCPH-30000. La réparation de cet appareil ne nécessite que des outils communs, mais peut s'avérer compliquer.
Questions au sujet de 161 Voir tout
Browser/System Configuration on PS2
When ever I turn on my PlayStation 2 it pops up a screen that says
Browser
And below it it says
❌ Enter
Répondre à cette question J'ai le même problème
Indice 1
Commentaires:
How do I get out of this please
par
When i turn on me ps2 even if games in it or not it says browser and system configuration and the light blue ball that would usually move around on the main screen is not moving
par
Ajouter un commentaire
4 solutions
Réponse la plus utile
either you have no disc in the system or it is not reading disc
Cette réponse a-t-elle été utile ?
Indice 2
Your PlayStation 2’s eye is probably wore out. If you call Sony, they might be able to assist you.
Indice 0
Indice 0
If the blue dots stop spinning on your PS2 and just stay in one solid ball then that usually means that the Clock battery in the system has died and will need to be replaced, on the fat models (SCPH-10000/30000/50000) It is usually located on a little board mouted to the left side of the DVD drive if it isn’t thn it will be located on the main board and will require further disassembly, just pop it out and replace with a CR2032 battery with the flat side facing outwards (writing towards you) on the slim models (SCPH-70000-90000) it is slightly different the battery is located in a little dip infront of the DVD assembly and has a little wire plugged in to the console, replace with the same one of if you can’t find one and are handy with a soldering iron (or someone you know) then get a normal CR2032 Coin cell and there are plenty of guides on YouTube showing how to do it. Note once you replace the battery the Date, Time and other things will have to be reconfigured in the system settings.
Liam H.
Indice 0
Ajouter une réponse
nathanielcollins20 sera éternellement reconnaissant.
Afficher les statistiques:
Dernières 24 heures : 5
7 derniers jours : 40
30 derniers jours : 188
Total : 7,690
