Aller au contenu principal
L'Apple iPhone 5s fut annoncé le 10 septembre 2013. La réparation de ce modèle est très similaire aux modèles précédents et requiert des tournevis ainsi que des outils pour faire levier. Disponible en version GSM ou CDMA, 16/32/64 Go de stockage et en argent, doré ou gris sidéral.
Questions au sujet de 3924 Voir tout
Why isn't my battery charging after replacement?
Hey guys, I just replaced the iPhone battery with the new one. Everything went well during the replacement.
But now, I am facing a problem. The phone shows the correct charging symbol including buzzing when the cable is connected, but the battery is not charging...
What I have tried so far:
- Resetted the iPhone
- Reconnected all parts
- Tried the old battery
It is all similar to the guide. But still, the phone says that it is charging the battery, but in fact, the battery is not gaining more power.
Can anyone help me with this?
Répondez à cette question J'ai le même problème
Ajouter un commentaire
4 réponses
It could need a new charge port or it may be a problem with the logic board.
Cette réponse est utile ?
Connect your old battery if it charges then that old battery is a dud.
I have had these batteries so many times.
Hi here is the solution please click on the below link and watch then tell him about your phone problem i am sure you will get a good solution
https://youtu.be/ItJnD-p2SEE
Check on the logic board near the battery connector. There are a few tiny components. Check the FL17 component, it goes to the gas gauge line. If it is missing, this will happen. If it is missing, send it to @jessabethany, she can fix anything :)
Ajoutez une réponse
Florian Meier sera éternellement reconnaissant.
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 67
