Aller au contenu principal
Modèles A1237 ou A1304 / processeur 1.6, 1.8, 1.86 ou 2.13 GHz Core 2 Duo
Questions au sujet de 310 Voir tout
white screen problem on boot
I own an apple macbook air model number a1237 that has nothing but a blank white screen on boot after the startup sound. I have tried two different screens and lvds cables. it works great on an external monitor thought. any help would be greatly appreciated.
Thanks,
Cody
Répondu ! Afficher la réponse J'ai le même problème
Indice -1
Ajouter un commentaire
4 solutions
Solution retenue
Hook it up to an external monitor to check the GPU and logic board.
Indice 5
Commentaires:
ill have to test that when i get done with class today. if it were to work on an external monitor, any thoughts on what could be wrong with it?
par
Please list the last three letters of your serial number. Thanks
par
y51....and it does work with an external monitor my previous post that said it didnt was incorrect
par
The LVDS is causing the issue and needs to be replaced by a professional certified Apple Technician with appropriate device.
Update
1- The connector between the logic-board and the CABLE that comes from display is loose.
2- Other possibilities?
Indice 0
north bridge(gmch) error-fauller
Indice 0
Cette réponse correspondait à l'origine à une autre question .
I had this same issue. White screen, chime, responded to light sensor. Hooked to external monitor, would get video there. But I could only get a white screen on the internal monitor. I swapped the logic board with a known good logic board and this fixed the issue. So I'm going to say it's a logic board issue, strange as it is, or a logic board to LVDS connector issue (all I did was remove this, the HDD connector, data/usb connector, airport card connector, magsafe port, iSight connector(?), and top case connector, to swap the logic board). I had a !@#$ of a time finding any info, so I hope this helps some people out there. I'm going to investigate and see if I can find any further answer to this.
Indice 0
Ajouter une réponse
Cody sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 5,422
