Aller au contenu principal
The BLU Vivo 5 is an Android smartphone produced by BLU, an American consumer electronics company. The 5 was produced through a partnership between BLU and Vivo Communication Technology Co. Ltd., a Chinese technology company. The BLU Vivo 5 was released in February 2016.
41 questions Voir tout
Where did my call log and messages go?
So I have all of my contacts but all of my messages and call logs disappeared. When I go to my settings it says I have all of my messages but when I open the app or hangouts I have zero threads. It will also notify me when I have a new text message but I cannot see said text anywhere. I tried resetting my messaging settings and it didn't work. I'm incredibly confused. Help?
Répondre à cette question J'ai le même problème
Indice 8
3 commentaires
I have a vivo y21l phone but after 4 months of buying it does not show any recent calls and missed calls rather it shows old calls what to do next..
par
Have you solved this problem? It happened to me. But i still cant fix it
par
Hello
I have vivo v5 and i was block a number and the block number and messages remove from my message inbox.
My all messages go in to i manager block messages.
I want to move that all messages from i manager block message inbox to my vivo v5 default message inbox after unblock that number.
How to fix this issue please help me to fix this issue.
Thanks
par
Ajouter un commentaire
11 Réponses
Réponse la plus utile
It may be because you accidentally turn on the "guest mode".
My sister also has a vivo 5 and experience pretty much the same problem. She can't see any call log, and all the picture in the album are gone.
In the file explorer I was able to find the pic under DCIM folder, but don't have the access to view it. The phone pop me a message saying I was not allow to see them because I was in the guest mode.
So I go to setting->security-> and turn off "guest mode". Everything come back, hope it also work for you.
Indice 25
22 commentaires:
Oh. Fantastic. Thank you very much for your suggestion. I had the same problem and I very much worried. After seeing your suggestion and tried off from guest mode. I the problem solved. Thank you very much.
par
Thanks you I turned off my guest mode like you suggested and my call and messages are back,, thank you sooooo much
par
I can't find the guest mode on my Vivo 5R.
Can someone help me ASAP. Justice
par
I can't find guest mode either, any help?
par
Thanks.... It works
par
Voir 17 commentaires en plus
Justice Sackey I emailed Blu support and they told me to go to settings, security, unknown apps installed, open it download guest mode doc, then you can close that setting back to unopen. It worked I got everything back.
Indice 0
5 commentaires:
What is the process of delete call log in vivo v5 phone
par
@aliceca , I have same problem with 5R, I cannot find "unknown apps installed". Is it hidden under other section? Thanks.
par
After the phone being updated to the latest version *v24_generic_6.0_07-6-2017, the "Guest-Mode" check box showed up on "Settings" - "Security". Finally, I got the call logs back.
par
I'm experiencing the same problem. I am unable to find any of the options in security, and not sure how to get the phone to update as mentioned above. Would be grateful for any suggestions... cheers
par
I have an XL2 with the same problem, I followed the instructions and got everthing back. Thanks @dzpcool!
par
Thanks for this info...I now have my messages, pictures and call log back.
Indice 0
It worked for me .Thanks
Indice 0
1 commentaire:
hey everyone, I have vivo xl and after a certain date I have lost some messages. I never lost my call log or contacts... HELP!
par
This is probably because your guest mode is turned on. Go to settings>security>guest mode and turn it off. Hope it works for you.
Indice 0
1 commentaire:
It doesn't have that option when I click security
par
Hello
Thanks
Indice 0
I have Lenovo k6 note with venom os
I can't see my recent calls and messages..
What to do ??
Indice 0
Same here. I can't see my call log or pictures.
Indice 0
Your a deleted it or your phone glitches out. Don’t be too hard on your self, computers are complicated.
Indice 0
I can not see the Miss calls numbers on my
Indice 0
Thank you,
Your answer to the problem worked like a charm. Resolved within 30 seconds vs. my having spent a lot of useless time before reading your answer. Thanks again. Mike M 3/25/2020
Indice 0
Ajouter une réponse
Angie kriess sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 9
Total : 34,888
