Aller au contenu principal
Modèle A1238 / avec disque dure de 80, 120 ou 160 Go / façade en métal noir ou argenté
903 questions Voir tout
Partial/Broken Display after closing the casing! iPod Classic 120GB
I replaced the battery in my ipod, a check to make sure all was working properly BEFORE closing up the casing revealed all was indeed working correctly.
But after closing the case, the display is now messed up, with part of the image missing and the rest broken into lines with kind of splatter marks across the screen.
Is this just a screen replacement job, a connection problem, or worse?
Any help greatly appreciated!
Répondre à cette question J'ai le même problème
Indice -1
2 commentaires
Thanks. Yes - it looks like I may have squished the LCD on closing the case then.
par
Nice, fine if you could mark my answer then. =)
par
Ajouter un commentaire
2 Réponses
Réponse la plus utile
"Splatter marks"?
Sounds like a screen replacement. You probably cracked the LCD..
Google "cracked lcd" and see if your screen looks similar.
Indice 1
Hi Rousp
Thought I would just add (for everyone's info) that I received a new screen this morning.
Fitted it, and it works perfectly once again. Your prompt answer saved me a lot of time, I think I've marked your answer correctly, let me know if not.
Thanks
Indice 1
2 commentaires:
hi Tony. You should click on "accept answer".
par
Hi Tony, glad to hear that. As bjoernen dk says you should click on "accept answer"
par
Ajouter une réponse
Tony sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 1,250
