I am assuming this phone is the one released in 2012. If that is the case, this phone was loaded with Android 4.0.4, which has quite a few security vulnerabilities. There is no official rom that I can find that you can reflash.
I backup your data first, then try a factory reset via recovery to see if the malware really did violate your system files. If it did, time to get a new phone. If not, download anti virus ASAP.
To get to recovery:
At first switch off your phone.
Then press and hold the Volume Up + Power at the same time for a few seconds.
Release held keys when you see Recovery Mode.
Then press the Volume Down to select option "Wipe Data/Factory Reset", and press Power button to confirm.
If it does not go into Recovery Mode, Use Volume Down instead of Volume Up on the second step.
A voté
Annuler
Indice
0
Annuler
Faites défiler ce fil pour trouver l'endroit approprié pour y placer ce commentaire. Cliquez ensuite sur « Ajouter un commentaire à cette contribution » pour le déplacer.
This sounds like Malware, Adroid as very few actual viruses that harms the phone "DroidDream virus" That message was probably so you call a fake tech repair shop...etc. I would look through the SD card on through a File Manager, and Files that are saved in phone memory, or a PC and make sure all the files are *Yours* and delete any unknown Misnamed files, then restart the phone.
- Did you try a hard reset by holding the power button for 5 to 15 seconds until screen flashes?
par Repair Pug
I have to say these are the shittiest phones I've ever had
par Sherrie Ford
