Aller au contenu principal
The Shark Rotator NV502 vacuum was made in 2013, weighs 15.5 pounds, and includes a lift away handle. The vacuum can be used on both carpet and hardwood floors.
Questions au sujet de 16 Voir tout
Why is my vacuum spitting out dirt?
My vacuum started spitting out dirt from the front onto the floor. Any help is appreciated.
Thank You
Répondre à cette question J'ai le même problème
Indice 1
1 commentaire
My shark rocket vacuum is shooting dirt back i can feel it hit my feet and bought new filters and clean brush and took apart to check for clogs and unclogged in the main tube and it is doing it still , I'm ready to throw vacuum out.. Any recommendations would be appreciated thank you
par
Ajouter un commentaire
3 Réponses
Réponse la plus utile
First, make sure there isn’t a clog in the vacuum. There are three places where clogs are most often found: behind the brush roller, the hose, and the dust cup air duct. Also, you might need to clean the HEPA filter. If the filter is dirty it could prevent the vacuum from blowing out any air which could be the reason the vacuum is blowing out dirt. The steps to check for clogs can be found in the troubleshooting guide and the HEPA Filter replacement guide.
Indice 3
I am experiencing the same problem so I decided to take it all apart. Found that when their is a clog the dirt gets pushed past the filter and into the motor “FAN”assembly. Every time I turned it on it blew dust. After I cleaned out the motor/fan and rinsed the filter problem when away. My recommendation is to run it outside until no more dust, clean the filter or replace and keep maintaining it after every use correcting clogs as they occur. No simple answer use, clean, store.
Indice 1
1 commentaire:
I have no idea how to take my shark rocket apart. Litter is dumped all over the carpet I just vacuumed!
par
It turned out my filter was clogged on the inside (inside the compartment where the debris collects, right in the middle of the vent passageway). I had already cleaned out the compartment but turns out inside it was still blocked in the air passageway. I carefully cleaned it out and poof! the vacuum cleaner started working beautifully again. It's always a good idea to take it apart and look for clogs anywhere.
Indice 1
Ajouter une réponse
Cory Holt sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 57
7 derniers jours : 342
30 derniers jours : 1,632
Total : 74,000
