water on passenger side
when it rains i find water on the passenger side exactly in the corner where the band stripe ends. in the leg room is all dry.
ia had so much water that behind and under the passenger seat every thing was wet.
i just lift the carpet and i had some 2-3 cm of water there.
it is not from the a/c because the carpet was dry and i did not used the a/c after i dryed the carpet
please help
Indice
0
Hi, Just a suggestion. Apply (spray puff? bottle) baby powder along inside of door frame(s) then close doors and hose gently around doors starting at the top. You should be able to tell where the water first enters as powder will be wet. Obviously it will run down the frame if leak is at the top.
Do you have roof rails? perhaps the leak is through there and coming down the inside of the body shell.
par jayeff
