Aller au contenu principal
Ordinateurs portables produit par Fujitsu.
Questions au sujet de 65 Voir tout
screen turn on and off when I touch the laptop lifebook s751
screen turning on and off when i touch the laptop mostly on the body, everything is working ok even when i touch the screen ,, so i dont think so its about screen.. i tried to open it up but all wires or sockets where in the right place.. so i wonder what it might be.. should i just change the main board?
what you think guys?
thanks
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Solution retenue
first u need to check the connector cable from monitor to the board it's likely the issue here , maybe not connected well from both side u better check or corrupted need a replacement.
Indice 0
1 commentaire:
i checked everything, i disassembled down to the main board, everything looks very ok. ports are solid, but when i push some where around to the CPU fan area picture will gone, and i have to shout down and turn on again. i tested the main board alone to be sure nothing is shorting between sink and main board, but still same result..
any idea?
Thanks
par
Ajouter une réponse
frankdez sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 72
