Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Il s'agit de la première génération du Ford Escape, un SUV crossover compact. La production a débuté en 2000 pour le modèle 2001.
How do I reset the cd player in my Ford Escape?
i recently had the battery unhooked from my 2007 ford escape and when i hooked it back up the cd player shows that there are no cd's loaded but in fact there are 6 loaded and were loaded prior to unhooking the battery. how do i reset the cd player so that the cd player will recognize that they are there?
Répondre à cette question J'ai le même problème
Indice 6
5 commentaires
How do I unlock my code
par
i have 6 cds loaded into my ford escape and i need them out and my car is not recognizing that they are in there. how do i reset my car
par
par
I would like to no how to unlock the stereo in my 04 ford excape for the code to be put in if u can help me plz nd thz
par
@tamsra711 i have asked the same question and got no replies
par
Ajouter un commentaire
7 Réponses
Réponse la plus utile
Remove the front panel of the car CD player > Press the Reset button you will find after removing the player panel > press the button once using some thing stick > reintsall the panel.
Indice 1
10 commentaires:
agreed +
par
will this work for the factory cd player or is this for an aftermarket cd player?
par
Where is this button you talk about? I've had mine off at least three times and I cannot find a button to reset anything.
par
I failed to mention that my Escape has the Audiophile CD-6 system in it, does this make any difference?
par
Reggie, yes, It's a different player. Is it showing an eject error?
par
Voir 5 commentaires en plus
I had the same problem. I'm not sure which unit you have but mine is the Audiophile, the upgraded version with an amp and bass booster hidden in the passenger side back panel. I took the unit to this electronic fix it guy, he said it would cost me at least $250, I laughed and said see you later. He said the motor was frozen up so I accepted that. I went to ebay and found one exactly like mine for $125 so I bought it. I installed it and it's like new. My point is most likely you won't find anyone who can fix this problem unless you want to pay that much which to me it isn't worth it. Please remember this is about my Audiophile unit not the stock one. Hope this gives some insight.
Indice 1
1 commentaire:
hi,
i do have 2002 ford escape the radio wont start but sometimes is coming in but most of the time is always off. can someone help me with this? tnx guys
par
My radio and time not coming up.
Indice 1
1 commentaire:
My 03 escape xlt cassettes won't load or come out if any in there!!!. Eject button not doing anything.
par
Ford radio unlocking step by step :
https://www.youtube.com/watch?v=0KfNMuFF...
Indice 0
The issue could be resolved by doing the following:
1. Remove and unplug the unit using DIN tools (2 u-shaped tools that fit into holes on your stereo. Get them at most automotive stores) Instructions: https://youtu.be/zEyijBM1xMQ (It might require a fair bit of wiggling, unlike in the video)
2. Unscrew and remove the top metal casing plate
3. Manually remove the top disc, which should be accessible through the top of the device.
Once you replace the unit it should automatically recognize the remaining discs and allow you to use the machine as normal.
I hope this helps.
Indice 0
1 commentaire:
Thanks! Will now go make a set of din tools!!!!
par
Please can someone help me out. My ford escape 2008 radio cannot ON showing audiophile, please what can i do. Thanks
Indice 0
My Ford CD player is blocked how to reset it
Indice 0
Ajouter une réponse
joel sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 37
Total : 48,699
