Not booting after lower case replacement
(Also posted at step 48 of Lower Case replacement)
(The following happened while performing a lower case replacement. I had previously replaced the left display hinge with no problems)
When I removed the motherboard, a small nylon "pin" came out. It's about 5mm long, the head is about 5mm around with a flat side, and the pin is about 3mm dia.
I cannot determine where it belongs, and the system will not turn on after I re-assembled. I have double checked all connections several times and my only suspect is this pin... Can anyone help me determin EXACTLY where it belongs?
The symptom is the system will not start up when power button is pressed (no screen, no lights on cap lock, num lock, or power light on front right). The power cord lights up, and the battery charges properly.
Any help would be appreciated
(ETA: specific request)
