Aller au contenu principal
4ème génération de l'Apple iPhone. La réparation est relativement simple, mais la vitre avant et le LCD doivent être remplacés ensemble. GSM / capacité de 8, 16 ou 32 Go / Modèle A1332 / noir et blanc.
2375 questions Voir tout
Why my screen got dark blueish with horizontal lines after charging
Is this means that screen has to be replaced or maybe is another reason ?
And also after I replace battery I can"t get it charge.Phone gets very hot,
Regarda
jpgo@op.pl
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
2 commentaires
Was the screen changed recently?
par
Thank You for an answer,but none of his had a place.Phone wasn’t disassemble and screen wasn’t replace.This means that screws couldn’d be misplaced.Phone was perfectly ok. till last charge.After charging screen was ok. And than for some reason screen went blueish.Vibrator still works.I thought that maybe battery was flat,so I bought new one and try to charge,but it couldn’t only phone got very hot.
par
Ajouter un commentaire
2 Réponses
Solution retenue
This is a very common issue when the screen has been user replaced. If the wrong screws have been installed in the wrong place, the screen might have a blueish tint with other issues arising as well. This is because the longer screws would hit a PCB on the other side. Try removing all of the screws you had to take out and try to see if that fixes the problem.
Indice 0
1 commentaire:
par
Indice 0
Ajouter une réponse
Jerzy Goral sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 52
