Aller au contenu principal
Modèle mi-2009 A1278 / Processeur Core 2 Duo 2.26 ou 2.53 GHz EMC 2326
745 questions Voir tout
Why does my MacBook Pro shutdown when the battery is between 50-30%?
My MacBook Pro 13" 2009 Unibody shuts down randomly. I purchased it from a friend. I noticed the battery needed to be serviced and the body below the keyboard would get hot, so I got a new one installed at a local Mac repair shop. New battery is great, low cycle count. Heat issue was better. It even charges up to 100% percent no problem. But when it is off the charger and goes down to say below 50% it will automatically shutdown. I plug the magsafe back in and it boots up. Sometimes I do notice it can get down to below 20% and then shut down. What do you guys think? A battery or logic board problem? Thank you in advance for your help!
Répondu ! Afficher la réponse J'ai le même problème
Indice 3
1 commentaire
Had a similar issue when unplugged at 55%. It was fixed by resetting with:
https://apple.stackexchange.com/question...
Take anything you read with a grain of salt.
par
Ajouter un commentaire
2 Réponses
Solution retenue
@boogiexl ,Eddie. Checked a couple forums and found this, Link 1,2 You can try a battery calibration or Link 3 Reset Mac SMC (System Management Controller) use this reset when experiencing power management and battery problems: Mac isn’t turning on, sleep isn’t working, random shutdowns and reboots, battery isn’t charging, Good luck.
http://www.makeuseof.com/tag/calibrate-m...
http://www.tomsguide.com/faq/id-2349626/...
http://osxdaily.com/2010/03/24/when-and-...
https://support.apple.com/en-ca/HT201295
Indice 2
As stated above, try a SMC Reset. If there is no change. Try reinstalling your OS and Verifying all Updates are applied. If issues still occur, have an Apple store or service provider run a MRI test, there is chance that the battery is not below the FFC % yet still causing shutdown like failure.
Good Luck,
Henri
Lead Service Technician
MacSuperStore, Santa Barbara
Indice 0
Ajouter une réponse
Eddie Bugayong Jr sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 5
Total : 18,813
