Aller au contenu principal
Commercialisé à l'origine le 22 janvier 2005, le Mac mini est un ordinateur de bureau de petite taille fabriqué par Apple Inc. Actuellement, il est l'un des quatre modèles de bureau de la gamme Macintosh et sert principalement d'alternative à l'iMac tout-en-un.
872 questions Voir tout
startup and boot don't works,
Hi all,
I have a Mac Mini mid 2011 i7 2x HDD 750GB and it has the following problem, it is to boot inconsentiously, it does the chime, it loads the system halfway and it turns off and on, it turns on the front led, and you hear the cooler And sometimes it goes until the maximum rotation. Keyboard is unresponsive.
Some help already tried to make the boot safe but with no luck. the
thanks
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Solution retenue
Pull the drive out and use an external bootable HD (USB thumb drive) Are you able to boot up then?
Update (12/08/2016)
Then the power supply is what I would focus on first. Also make sure your power cord is good and you have clean power (using a UPS (best) or surge suppressor, with either clean AC power & good ground to power the system.
Indice 3
1 commentaire:
Yes, but not all time, I'm need put power on/off several time for Mac boot w/ chime video anda normal boot
par
Ajouter une réponse
guedes Jr sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 94
