Guys, do yourselves a favor and buy the Ice Surrender tool mentioned (by the inventor/seller) in one of the comments above. I'm not affiliated with him, but it just works -- it's the right tool for the job. IMHO, it's well worth the (small amount of) money to have a solution that fixes the problem with literally only seconds of effort. It's infinitely easier than most of the solutions described here. Heat water, suck it into the syringe/tube assembly, stick the tube up the dispenser tube till it stops, and then push out the hot water, pushing the tube further in as the ice blockage melts. In a few seconds, you'll have melted the whole thing.
Using a blow dryer was useless for me, though granted, I wasn't willing to spend 10 or 15 minutes or more doing it, as some here seem to describe.
On the recommendation of a GE tech, I had previously tried turning the freezer up from 0 to 5 degrees. Just got too soft ice cream, water line didn't stop freezing on me.
Now the temp is back down, ice cream is good, and the dispenser runs fine. When it freezes again, I know I'll be able to clear it very quickly, with the tool.
A voté
Annuler
Indice
0
The only thing worse than GE refrigerators is GE service. Don't purchase GE
par smith
I have tried a hair dryer on both the reservoirs and the freezer door but to no avail. Should I turn the freezer and refrigerator sections completely off and let the whole unit thaw out to see if that helps?
par billhopper25
I have a side by side GE. I have read the comments, however I believe my problem may be different.
When I try to get water it fills up a quarter of the glass while making noise then comes out really slow.
I have used the hair dryer and fished some weed eater line up through the tubing of the door.
I am at a loss and suggestions?
par Dave
I have the same problem. Everything was working fine before I replaced the filter and now like you a quarter cup fills up and then it trickles until it completely stops. If I wait 5 minutes and try again the same thing.
I put the old filter back on and the same thing so that ruled out the filter. I even put the bypass on and same thing. No sign of frozen lines so I started to wonder if there was air in the line?
I noticed a small leak coming out of the what appeared to be the valve in the fridge and when I inspected closer there is a hair line crack around face of the valve where the filter screws into. I think this is my problem but not 100% sure.
Anyone else ever run into this?
par Yokster
Same problem here, but I unplugged and emptied the refrigerator and freezer to let the water line thaw. After all day of thawing, the water did not dispense. I removed the back cardboard panel and followed the water line from the bottom of the front panel. There it was broken in two...probably from age... I took the coupling from the front off (this one has 2 different sizes) and checked to see which size fits the back water line. The larger size fit, picked up a coupling at HD for $4.25, put it on the water line and tested... no leaks and the water is back flowing.
par Jon Rozansky
Voir 36 commentaires en plus
