The order in which your drivers are installed may well determine if your touchscreen will work. To fix this issue, you need to load the needed drivers on a flash drive or another machine. I suggest <h>www.toughbookdrivers.com/drivers/cf-29/</h>
First, restart your computer in safe mode (pressing [F8] as you are cold-starting up).
Then, using CONTROL PANEL, remove all drivers (Video, Audio, Mouse, Peripherals, etc)
Finally, install the Touchpad/Touchscreen driver FIRST. Install then video, then audio, then the rest....EXCEPT save the LAN and WLAN drivers, respectively, for LAST. If you have GPS, add after LAN and WLAN drivers are installed.
If this doesn't work, it's likely your touchscreen card went bad...it is a weak link with these units...especially the Mk IV's or V's.
A voté
Annuler
Indice
Annuler
Faites défiler ce fil pour trouver l'endroit approprié pour y placer ce commentaire. Cliquez ensuite sur « Ajouter commentaire à cette contribution » pour le déplacer.
4 commentaires
Did you activate your Touchscreen in BIOS?
What happens when calibrating?
par lingster
Update the mouse driver to the touchpad/touchpanel driver for your model number from the panasonic website. Windows will automatically use a generic mouse driver because mouse "has" to work. It's is the ps/2 mouse driver that must be updated to the correct driver then your touchscreen should start working correctly.
par brokndodge
I'm having problems with my touchscreen also. I have a air force only model and can't find the drivers. If anyone could point me in the right direction I would appreciate it. Panasonic was no help at all
par Henry Skaggs
It's a Cf-29G
par Henry Skaggs
