Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
The second-generation Dakota began development in 1991 and frozen for production in January 1994.
Questions au sujet de 59 Voir tout
Wont shift out of first gear
98 dodge dakota 4x4 v6 3.9 Wont shift out of first and the trans temp light comes on
Répondre à cette question J'ai le même problème
Ajouter un commentaire
Kits pour Nintendo Switch
A quick fix to get back in the game
Shop Switch Kits
Shop Switch Kits
1 solution
Réponse la plus utile
Either the fluid is very low, or fluid is not being pumped through the transmission.
Start out first by checking the transmission fluid while the truck is at operating temperature. If the transmission oil is low, check under the truck for any signs of leaks. If it's leaking from the transmission pan, transmission lines, or at the radiator... it's usually an easy fix.
If your transmission fluid is ok or low without signs of leaks, have it towed to a transmission shop. Don't drive it or you may risk more damage.
Cette réponse a-t-elle été utile ?
Score 1
Ajouter une réponse
Corey jail sera éternellement reconnaissant.
Afficher les statistiques:
Dernières 24 heures : 2
7 derniers jours : 6
30 derniers jours : 17
Total : 1,001
