My phone is keep saying android is starting
phone is keep repeating its self saying android is starting
If this is like what happened to me you should be able to see the home screen and pull down the status bar. If this is the case this answer will tell you how to fix it. The problem is that you somehow got rid of your launcher.
Fix 1.
very easy but will only work if you have cwm recovery or twrp installed if you don't know what this is you probably don't have it installed
Go to this site http://opengapps.org/ and download the aroma version for your android place it on the sd card or internal memory using your computer.
Then boot into recovery and start installing the open gapps zip you downloaded and during installation select custom then select to install google now launcher nothing else finish installing and reboot now it should work
Fix 2.
Download this if you are on android 4 or above: https://goo.gl/bEIA9E
Download this if you are on android less than 4: https://goo.gl/0ieuWz
Now make your way to settings in android 4 or above pull down the status bar at the top then click the little gear android less than 4 click the button by the home button that looks like a list then click settings after you are in settings follow the instructions in this article to side load the apk file you downloaded above
: http://www.greenbot.com/article/2452614/...
after you sideload the file using one of the methods in the above article restart your device and it should work
Cette réponse a-t-elle été utile ?
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 63
Total : 1,804
