Aller au contenu principal
The 1999 Chevrolet Malibu is part of the fifth generation (1997-2003) manufactured by General Motors. This is the first smaller, front-wheel-drive Malibu that General Motors put back on the market after the Malibu line was temporarily discontinued in the early 1980's.
Questions au sujet de 53 Voir tout
I have no air flow through my vents. Fan can be turned on hi and air i
I have a 2000 Chevrolet Malibu. Just got it and I have a ventilation problem.
I have no air flow. Can turn the fan on hi and still the air is at an idle flow through the vents. I have got hot and cold air and the fan works as well as all the different vent selections. Something is blocking the air from the fan to the vent openings. What part could this be.
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Solution retenue
@mrbryden ,Cory, from what you are saying the fan and fan speeds work and vent selection works. I suggest you check the in cabin filters for clogging. You may have to also vacuum out the HVAC plastic ducting in same area with filters removed, as good as you can also. Link below to location and how to access cabin filter and a trouble shooting link in case this is not the problem. Good luck.
https://www.youtube.com/watch?v=rp5m-iYn...
https://www.2carpros.com/articles/low-or...
Indice 2
2 commentaires:
Hi I P faff,
I thought the same thing but, I called GM and they tell me that. That year of Malibu did not have a cabin filter and the owner's manual doesn't lost a cabin filter for it either. So I would say that idea is a bust. Have any other ideas?
par
@mrbryden , Cory did you view the second link and check those areas.
par
Ajouter une réponse
Cory sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 366
