Aller au contenu principal
Pour réparer ensemble - Je crée un compte
The smaller of Apple's MacBook Air laptops featuring dual microphones and 802.11ac Wi-Fi connectivity.
No Thermal paste on 2nd IC
Hi, I'm cleaning my macbook air after a coffee spill and have disassembled the logic board. when removing the heatsink I noticed that only onw of the two ICs had thermal paste. when I reassemble should I apply thermal paste to both ICs or only the one that had this one initially
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Ajouter un commentaire
2 Réponses
Solution retenue
Yes, you should put thermal paste on both of them.
One is the CPU die. The other is the hub controller die.
https://cyberraiden.files.wordpress.com/...
Indice 1
5 commentaires:
Whoops! Not Correct!
The Haswell series has an intergraded GPU chip (the smaller chip on the carrier). The CPU & PCH are combined on the larger chip.
As for thermal paste Intel recommends not applying thermal paste on the GPU element (Yes I know it sounds a bit odd). I think the issue here is the transference of heat from the CPU/PCH to the GPU.
Here's a bit more on the chip: On-Package PCH, The First Single Chip Haswell
par
@danj You can go argue with iFixit because I got the information from the teardown.
Step 10.
MacBook Air 11" Mid 2013 Teardown
par
Take a look at the either of these IFIXIT guides: MacBook Air 11" Mid 2013 Heat Sink Replacement or MacBook Air 11" Mid 2013 Logic Board Replacement note the small chip is bare.
par
@danj I think it would be a good idea to put thermal paste on the Intel platform controller hub regardless.
par
Ha, it's a GPU.
par
It truly doesn't matter what the IC is. If it's under a heatsink and has its own contact piece, it won't hurt to put thermal paste on it.
Indice 1
1 commentaire:
On my MacBook Air (11", 2015, i7) the smaller chip had no thermal paste. Also, the part of the heatsink that is above the smaller chip is slightly higher (towards the bottom cover) than the rest of the heatsink. To my eyes, at least, it seemed that that part of the heatsink would not (even with thermal paste applied) touch the small chip.
par
Ajouter une réponse
J Lycklama sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 38
Total : 2,294
