Aller au contenu principal
Apple a lancé l'iPad Air, la version mince des iPad précédents, le 1er novembre 2013 dans deux couleurs au choix : gris sidéral ou argent. Il emploie le processeur A7 personnalisé et est livré dans des configurations 16, 32, 64 et 128 Go.
577 questions Voir tout
My iPad Air will not charge. The female port is damaged.
I took my iPad Air into Apple to see what was wrong with it. It was determined that the female port for charging was damaged. They offered me a refurbished iPad Air for $350. Can this be fixed?
Répondu ! Afficher la réponse J'ai le même problème
Indice 3
Ajouter un commentaire
3 Réponses
Solution retenue
Luckily, Ifixit sells a replacement port for your tablet for only $20. The item code is IF128-007-1. But I recommend cleaning it like Ben said first. If that fails, buy the replacement and follow ifixit's guide to replace it.
Indice 5
2 commentaires:
Thanks to both of you!
par
I have this problem for ipad air 2. The female connector got pushed in and bent a bit (unlucky fall while olugged in). I don’t see repair instructions.
par
Lightning cable not plugging in fully? Clean out the gunk using a toothpick or equivalent to unblock the charging port.
Otherwise may be a bad charger port which if I remember correctly they are soldered onto the board which is not a easy thing to replace as it will require a lot of heat and experience.
Indice 2
I have the same problem contacted Apple they can fix it for AU$350.00
Indice 0
Ajouter une réponse
Missy sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 10
Total : 16,673
