Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Repair guides and support for electric and stove-top kettles.
My stove top tea kettle doesn't whistle
I have a Pafltzgraff Monaco stovetop tea kettle. It no longer whistles. Is there any way to fix it? I'd buy a new one if I could find that pattern.
Répondu ! Afficher la réponse J'ai le même problème
Indice 3
1 commentaire
Take the whisle apart, assemble again with the opening(s) in the plate line up with the opening (s) in the whisle. I have a brand new kettle, the whistle was just incorrect assembled.
par
Ajouter un commentaire
4 Réponses
Solution retenue
My first question would, does it fully heat up and boil? Steam vapor blowing out causes the whistle. Has the top been damaged or lost any parts?
Indice 3
4 commentaires:
It does boil. Is it possible the pop top isn't sealed enough around the sides? Would that affect the whistle? Maybe the steam isn't being forced through the whistle hole. What can I use so the steam can't escape around the sides? I'm just guessing that could solve the problem!
par
You could try running something like a pipe cleaner through the vent holes to see if they have clogged. If steam is coming out of the sides of the top, that sounds like the whistle vent is clogged up.
par
what if the cap is not sitting tightly over the spout?
par
arun - Basically it is a steam whistle, no steam pressure, no whistle. Think of a whistle you blow, no blow, no whistle.
par
I soaked the top of my teapot in 50:50 hot water and vinegar to remove hard water deposits. When that wasn't enough, I removed the screw inside the lid that held the "whistler". This was aluminum and still was a little roughness on the underside from deposits. I scrubbed it with non abrasive dish scrubber and the hot water and vinegar. I paid special attention to the edge where the cut outs were to make it whistle. When I replaced the aluminum piece, I lined up the cut outs with the holes on the top. I found I had to tighten the screw to slightly less than tight There needed to be a little room for the piece to vibrate. It worked fine after that.
Indice 2
1 commentaire:
Thank you Mimi! That worked perfectly!
par
I just fixed mine this morning. First, I ran a needle through the whistle hole and moved it around the edges of the hole to loosen anything built up there. This did not, however, work . . . until I, then, ran the whistle area under the faucet. Now, it whistles, again! Total cost of the repair: $0.00.
I am usually not very "handy," so this might end up being both my first and last post to this website.
Indice 1
I have had a whistling tea kettle for over 20 years. 2 for that matter. They both still work great. I moved, had packers, old one? Still looking. I thought I upgraded. XOX stainless stove top whistler. Worked for about 1 month.
Lousy whistle, however worked. No whistle now ruined induction stove burner. Just Great. WHY
Indice 1
Ajouter une réponse
Florence Stratas sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 31
30 derniers jours : 152
Total : 32,876
