Aller au contenu principal
Guide de réparation et support pour les Netbooks Dell incluant la serie Mini 10.
Questions au sujet de 17 Voir tout
type of hd in latitude 810/820
type of HD in latitude 810/820
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Ajouter un commentaire
3 Réponses
Solution retenue
cec331 , See links below for the specs. on the Dell d810/d820 and link for replacement HD, which if you need, can also do a google search on for better pricing. Good luck.
https://www.cnet.com/products/dell-latit...
http://www.dell.com/downloads/global/pro...
http://www.ebay.com/bhp/dell-latitude-d8...
Indice 4
Assuming your running Windows, go to the start menu, type in system info, and open it. It will give you information about the drive. An alternative way is to go to file explorer, right click on the C: drive, and select properties.
Hope this helps!
Indice 2
cec331,
This type of laptop uses an old 2.5" IDE laptop form factor (40-pin).
Due to the age of this, it is nearly impossible to find a new 40 pin.
On the bright side, technology has improved. I would suggest the following 2 options:
1) SD Card --> SD Card to Compact flash adapter --> Compact flash to 2.5" IDE adapter
2) Msata --> MSata to 2.5" IDE adapter
Let me know if you need links to recommended parts. What I don't know is the max hard drive size the D8xx series can handle.
Indice 2
Ajouter une réponse
cec331 sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 87
