Searching for service HELP
"SEARCHING" PROBLEM
Alright so I have a 64 GB iPhone 6 Verizon. I have tried EVERYTHING i have seen on here to where I know it is a hardware issue.
Now when I do *#06# the IMEI DOESN'T show up.
Keep in mind my wifi and bluetooth work so its not an issue at the top.
I am aware that the antenna is at the bottom of the battery, my question is that if the IMEI doesn't show up when i request it on dial-pad then is it definitely the baseband issue or could it still be the cellular antenna.
It also isn't the sim reader because when I don't have the sim in it will read NO SIM so the sim port seems to be okay because then when I put the SIM in it goes to SEARCHING
please help
1 commentaire
Do you know if the SIM you tried is a known working one? If no, have you tried other ones as well? If IMEI doesn't come up, it sounds like a hardware issue with the baseband. Has this phone worked in the past?
par S W
