Aller au contenu principal
Guides pour la version LTEde l'iPad Mini 2. Annoncé le 22 octobre et lancé le 12 novembre 2013. L'iPad mini 2, également connu sous le nom de mini iPad avec écran Retina, a tous les pixels de l'iPad Air dans un plus petit 7.9 " format.
62 questions Voir tout
Why is there no charge port replacement walkthrough?
I'm replacing the charge port on the ipad and there's no tutorial which sucks. I don't know if I should connect the new port on the back of the motherboard a specific way, please help!
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Solution retenue
Hi Felix. That's because it requires micro-soldering.
Micro-soldering flexes is tricky because you can easily melt the flex so this is really beyond what a DIY fixer should handle. If you have the tools and skills to do this kind of work, then you don't really need an iFixit guide ;>).
Look for an experienced micro-solderer in our area.
Indice 4
2 commentaires:
Thank's! I found this out, currently trying to learn defiantly not ready haha. What's the best way to go about learning how to micro solder?
par
There are lots of great videos on Youtube. Ultimately, ill need a good quality temperature controlled soldering iron and hot air station, flux and good tweezers and go from there.
par
Ajouter une réponse
Felix Robinson sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 3
Total : 1,011
