Aller au contenu principal
6ème génération de l'Apple iPhone, annoncé le 12 septembre 2012. La réparation de cet appareil est similaire aux précédents modèles et nécessite des tournevis et des outils pour ouvrir et faire levier. Disponible en GSM ou CDMA / 16, 32 ou 64Go / Noir ou Blanc.
Questions au sujet de 2501 Voir tout
My iPhone 5 screen doesn't turn on, but the phone connects to iTunes
For a couple months, my iPhone battery has been slowly expanding from the gas inside. I should have replaced it a while ago, but I was not aware that the battery was the problem until probably too late.
So it got to the point where the screen would have white lines across it periodically and sometimes the screen would go black with the backlight still on.
Finally, a day before I was going to replace the battery, I shut down the phone and it didn't turn back on.
What is odd is that the phone worked fine until I restarted it, and now the screen doesn't work. I assumed it was because the battery had finally met its demise, so I went ahead and switched out the battery (which was severely bloated) for a fresh one.
The phone still refused to turn on, so I plugged it in and charged it for a couple hours. Still nothing. I plugged it into my PC and noticed that iTunes still recognized it as my phone. So I did a hard reset by pressing the home and sleep buttons at the same time, still nothing. I went into recovery mode, and iTunes recognized it as such, so I wiped the phone from iTunes to see if that would work.
Frustrated, I opened up the phone and disconnected the display ribbons, then plugged them back in again and closed the phone again.
Nothing seemed to work. I feel like I have tried everything in my power. Is there anything else that I can do, or is the phone doomed?
Edit: Formatting (Benjamen50)
Répondre à cette question J'ai le même problème
Indice 0
Commentaires:
Currently the phone is able to switch on most likely but no display.
Can you confirm there is no display on the screen by checking if the screen shows a very dim display when iTunes detects the phone?
par
Whats The Error U were getting ??
par
Ben: The backlight is completely off
par
Ajouter un commentaire
1 Réponse
Réponse la plus utile
From your description I assume your screen is totally gone.
When batteries expand, they very often lift up the screen, pushing it out of its plastic frame, and in many cases damaging the screen assembly until a point of no return.
I suggest that you get your hands on a screen that you know is 100% functional, and try your phone out with that new screen. If it works fine, then your screen is damaged and needs to be swapped out, what I strongly suspect is the case.
Indice 1
Commentaires:
Yeah, that's what I thought. I will probably stop by the phone repair shop and see if I could get my hands on a full screen assembly.
par
Ajouter une réponse
Harry Starzec sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 55
