Aller au contenu principal
La version 2016 de la série d'ordinateurs portables Apple destinés aux professionnels. Dispose d'un écran Retina de 15 pouces, d'une résolution de 2880 sur 1800 pouces, processeur quad-core Intel Core i7, 256 Go / 512 Go /1 To / 2 To en options de stockage, RAM de 16 Go et un clavier équipé deTouch Bar. Sorti en novembre 2016. Numéro de modèle A1707.
260 questions Voir tout
Can I remove keys to clean inside them?
I spilled a sugary beverage on my keyboard and while it's still functional, some of the keys are sticking.
Can I can safely remove the keys to clean inside?
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Ajouter un commentaire
2 Réponses
Solution retenue
Your system is so new no one has documented how its done clearly. Here's the only YouTube I've found that even describes the keycap at all How to get your letter keys off your 2016 MacBook Pro sadly its a bit lame. I'm not sure if the butterfly keys used in the new retina MacBook is the same or not. There are a few YouTube's that go over how they come off.
If you can pop off the keycaps without damaging them you can use a cotton swab (Q-Tip) just dampened not wet! with distilled water to clean the sugary drink off of the parts internally. The caps them selves could be dipped in a container of water and then using a paper towel and can'ed air blown dry.
If the drink got deeper into the system it could cause corrosion damage which might not show up right away, So you may want to let a pro deal with taking the system apart to correctly clean things from the other side.
Sadly Apple won't repair liquid damaged systems and its voided the warranty coverage now. Even a pro may limit you on the warranty of the repair.
I would try going to an Apple authorized service center as my first choice here. I wish you luck!
Indice 2
I know its too late, but if others are using this page as a reference, here is how to remove the keycaps on these ranges.
https://thebookyard.wordpress.com/2018/0...
Indice 2
1 commentaire:
Its never too late.
Thanks a million!
par
Ajouter une réponse
Kathleen Fitz Gerald sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 2
Total : 3,091
