Aller au contenu principal
Version revisitée de l'iPhone 3G avec une vitesse de traitement plus élevée. La réparation de ce modèle est similaire à celle du 3G et nécessite de simples tournevis et des outils de levage. Modèle A1303 / capacité de 16 ou 32 Go / coque en plastique noir ou blanc.
Questions au sujet de 1961 Voir tout
iPhone 3GS charges up to 1% and instantly dies, boots repeatedly
So I recently bought a new battery for my iPhone 3GS claiming to be a 1600 mah battery. However, when I installed it into my phone it was stuck at 69% so I tried to charge it to 100% to calibrate the battery. But it stayed at 69% I played a 10 hour long video till it finally died (oddly enough still saying 69%). So I charged it again but it was at 1% with the little outlet logo instead of the lighting bolt logo. And then it died again tried turning on by booting showed 1% and died. I have recently removed an ifixit battery that it previously had that expanded I don't know if it could have damaged the phone in any way. And the last time I checked it, it said 100%. But as soon as I unplugged it, it died. What is going on with the phone?
Une réponse ! View the answer J'ai le même problème
Ajouter un commentaire
Fix Kits pour batterie de MacBook
À partir de $69.99
Buy Now
À partir de $69.99
Buy Now
1 réponse
Solution retenue
There is a "gas gauge" in the battery that communicates the battery charge level to the phone. If it is defective, then it will cause all kinds of problems.
Chances are you have a bad battery. Can you have it replaced by the supplier?
Cette réponse est utile ?
Score 3
Ajoutez une réponse
alexandercisneros2 sera éternellement reconnaissant.
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 2
Total : 59
