Aller au contenu principal
La version 2016 de la série d'ordinateurs portables Apple destinés aux professionnels. Dispose d'un écran Retina de 15 pouces, d'une résolution de 2880 sur 1800 pouces, processeur quad-core Intel Core i7, 256 Go / 512 Go /1 To / 2 To en options de stockage, RAM de 16 Go et un clavier équipé deTouch Bar. Sorti en novembre 2016. Numéro de modèle A1707.
259 questions Voir tout
Keyboarded and touchbar wont work
Hi , I spilled water on my mac , it couldn't turn on up to one week , after that It turned on but my touch bar and keyboard don't work , how can I understand it is related to the logic board or separately to the keyboard touch bar and sound ?
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
1 commentaire
Also how the !&&* did you break that thing anyway?
par
Ajouter un commentaire
3 Réponses
Solution retenue
Unplug the battery and clean it asap with this guide:
Electronics Water Damage
Indice 4
14 commentaires:
the only thing is that the haptic feedback is not working.. but I feel it worked before I closed the back case
par
@narimand Good! Is the touch bar and keyboard fully functional? Also can you take out the touchpad and clean that too, and check for rust.
par
and also my microphone doesn't work, I realised damage parts step by step .
par
@narimand Clean the LCD cable and post a picture of the socket on the motherboard, these often get damage.
par
Is there any relationship between a Lcd cable and microphone?
par
Voir 9 commentaires en plus
Check the underside of the logic board for liquid damage, and clean with 95%+ isopropyl if there is any corrosion. Sometimes on the 12" Retina (your model), liquid can get under this, usually around the CPU area.
Check the gold pins on both sides of the ribbon which goes from the trackpad to the logic board (curly one). If there is corrosion, this will be burnt, so it will need replacing. Also, check both sides of the cable which goes from the trackpad to the keyboard. It's very likely either the cable(s) or the trackpad PCB is bad if both the keyboard and trackpad aren't working, since the keyboard is plugged in through the trackpad.
If the keys are sticky, the keyboard will likely need replacing too.
Regarding the microphone, check for liquid damage around the small headphone jack board where this plugs in. Sometimes the microphone cable can be burnt, or the board is bad.
To be honest, I would recommend taking it to a repair company which has the testing parts available, otherwise you will find yourself spending a lot of money on parts to test. Try out what I said first though, to see if anything stands out :)
Indice 4
4 commentaires:
every parts now are fine , but my microphone won't work
par
@narimand try the audio board first, should fix the issue
par
I cleaned it but nothing happened
par
@narimand yes it is probably bad. If it had liquid on it, it is definitely going to be bad. This board is responsible for the audio so it is either this or the microphone itself, which is less likely.
par
here are pictures from my macbook
Indice 0
2 commentaires:
All the connectors looks fine, so honestly I have no clue. Maybe @refectio could help?
par
I haven't opened one of these up yet so I can only speculate. The first picture definitely shows contact with water. The damage may be behind that board as I can't really notice any obvious damage from the picture.
par
Ajouter une réponse
Nariman sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 3,261
