Hi,
When you say 'rebooted' did you mean a factory restore?
If not, try a factory restore and if this doesn't resolve the WiFi problem, verify the purchase date of the phone and then consult the manufacturer's warranty statement in the documentation that came with the phone as to what to do to make a claim for a warranty repair or replacement. There is a 12 month manufacturer's warranty on the phone.
Here is a link if you can't find it.
http://www.alcatelonetouch.us/warranty
Before performing a factory restore (or reset) using the phone's factory restore feature:
1. Backup the phone using the phone's back up feature. (A factory restore will erase all your user data and downloaded apps and will restore the phone to a factory default condition. It will be like when you first bought it).
2. Ensure that the battery is fully charged and remove the external SD Card (if installed).
3. Do not leave the charger connected when performing the factory restore.
Once it has completed the restore check the Wifi.
If it is still faulty you have a hardware problem, (see warranty claim above).
If the WiFi now works properly, restore the phone from the backup you made earlier, using the phone's restore feature.
Once it has restored, check the WiFi.
If it is still working correctly the reset has fixed the problem.
If it now faulty again then a downloaded app may be causing the problem. The trick is to find out which one. You will have to uninstall each downloaded app one by one and test the WiFi after each uninstall to see if it is working properly again. Once it does the last app that you uninstalled will be the culprit.
A voté
Annuler
Indice
Annuler
Faites défiler ce fil pour trouver l'endroit approprié pour y placer ce commentaire. Cliquez ensuite sur « Ajouter un commentaire à cette contribution » pour le déplacer.
10 commentaires
What worked? I am having the same issue And I have factory reset my phone and I am still having the same issue
par India Eiland
Hi. I just received a notification about your post. Have you read the solution above?? Tried closing your Bluetooth? It has worked for me and another person. There seems to be interference between wifi and Bluetooth.
par Stephany Frigon
why does my Alcatel one-touch say it's connected to Wi-Fi but when I go on the internet it says no internet
par Fay
I have tried factory resetting which solved the problem.
Then a week after the factory reset, the phone all of a sudden refuses to connect to wifi (or even see it on the list of available options). I don’t want to keep resetting the phone.
Any other suggestions?
par Ayesha T
My phone did an update which it failed to complete, after which I was booted off the wifi and Bluetooth kept crashing, so far bluetooth isn't crashing anymore, but my phone is not allowing me to enable the wifi, I've tried going through settings to turn it on, but I can't slide the indicator over for it to turn on (I can move it, but the phone still will not enable the wifi on it and the indicator gets yanked back over to "off", I've already done a factory reset earlier this morning, but nothing has changed.
par Lindsey Bell
Voir 5 commentaires en plus
