Aller au contenu principal
Comment réparer son MacBook Pro 13" Unibody, modèle mi-2012, A1278, processeur 2,5 GHz i5 ou 2,9 GHz i7.
1624 questions Voir tout
I have a Flashing Folder issue
Macbook Pro 13" i5 2.5 2012 Mid
When I start the macbook pro I get the flashing Question Mark. I've replaced the hard drive data cable and tried to boot from an external hard drive and still the same problem. Does anyone know how to fix this? Or is the logic board bad?
Répondre à cette question J'ai le même problème
Indice 1
1 commentaire
Have you reset the PRAM and SMC yet?
par
Ajouter un commentaire
1 Réponse
Réponse la plus utile
It's possible the replacement hard drive cable could be bad - I remember I ordered 5 of them once and 2 of them were dead on arrival.
Either that , or the hard drive itself requires replacement.
The flashing folder happens when the MacBook can't detect the operating system. If you have installed a new ribbon cable but the hard drive has failed, or a new hard drive but have not reinstalled the operating system, you'll see the flashing folder.
Easiest way to check would be to boot into either Recovery mode or off an install USB if you have one and load up Disk Utility.
If the hard drive appears and you can run First Aid on it and it passes, the drive should be fine.
If the hard drive doesn't appear when connected to the ribbon cable but does appear when connected externally, your ribbon cable is probably bad.
Indice 1
Ajouter une réponse
Renaldo Greenfield sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 92
