Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Le premier de la nouvelle génération d'appareils Nokia – le premier avec un écran 1080p, le premier avec un processeur Krait quad-core
No lights on the hard buttons--> external speaker fails -->micro fails
Hi guys,
you are my last hope !
The problems with my lumia 1520 began with the missing light of the back button, continued with missing light of the windows button, followed by fails of the external speaker in noise and loudness and ends up until now with not working microphone.
The phenomenon is that if I bend the 1520 by pushing on the upper left and the lower right corner and holding it in the middle of the back side, the lights of the windows and back button are working as well as the external speaker. So i guess the 1520 has a internal contact problem, caused by transporting it in the trouser pocket.
I just try to bend it the other way round but no effort so far. Would it be helpfull to diassemble the lumia 1520 and reassemble it again to fix the internal contact problems ? (it's only my root cause no idea if i'm right)
I very appreciate every type of help or answer.
Thanks in advance
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
My recommendation would be to do a hard reset (Settings | About | Reset my phone). You'll want to make sure your photos are all backed up to either SkyDrive or your PC first, and you're going to lose app data for apps that don't provide a backup method (SkyDrive, app's servers, etc). If you have the backup settings on then your apps will be able to automatically reinstall when you restore the backup. Also, if you have GDR3 installed you can do that restore from WiFi.
If after a hard reset the buttons still don't work, the problem is hardware. If it is still under warranty, contact Nokia for repair. If not, hopefully you've got insurance on the phone. Also, there are plenty of indie repair providers out there - you could check with them for a cost estimate, should you not be covered by insurance.
Check Nokia Lumia 1520 Manual for your more assistant support.
Indice 0
Ajouter une réponse
Nico Eberhardt sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 8
Total : 344
