Aller au contenu principal
Annoncé le 16 octobre 2014, identifiable par le numéro de modèle A1347 et EMC 2840.
197 questions Voir tout
PCIE SSD DIY in Mac Mini purchased in 2017
i have recently purchased a mac mini in jan 2017 from apple. I try to add a pcie ssd myself by getting ssd cable and a pcie ssd from an old mini 2014 ( which is a 32/24GB of toshiba ssd).
Unfortunately, the ssd is not detected in the mac os.
can any expert shed me some light? is the "new" boot firmware of mac mini 2014 not supported? do i need a very new apple pcie ssd?
thanks
Répondu ! Afficher la réponse J'ai le même problème
Indice 1
1 commentaire
Can you take some pics of the labels on the SSD and post them here so we can review what you have. It would be helpful understanding how you did the transfer and why. Was the other system dead?
par
Ajouter un commentaire
1 Réponse
Solution retenue
Apple has not altered things within this series.
So what worked in the first systems of this series (2014) still works in the current models of this series presently.
Are you sure you didn't damage or forget something in the process or have a known good (correct) SSD?
I have quite a few of these in our office and I've moved the SSD drives around without any issues.
Indice 3
3 commentaires:
thanks Dan. I finally figured out it was the cable issue. I ordered another one from another seller. The problem solved.
i cannot imagine it is due to the cable!
par
Hi Jona, could you send the link where you bought the new cable? I have the same problem... the system does not recognize my SSD and i think the cable could be the problem, the guy who sells the SSD to me says it is a cable problem... so i want to try a new cable before return with de SSD. I am trying to use a 256GB Toshiba SSD
par
I get my cables from PowerBook Medic:
- Flex cable for the 2.5" SATA HDD for the Mac Mini
- Flex cable for the Blade SSD for the Mac Mini 2014
You may want to review this if you are planing on using the blade SSD connection: The Ultimate Guide to Apple’s Proprietary SSD's
par
Ajouter une réponse
jona sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 1,068
