I've done about 5 of these iPhone 7 Plus' now. Never ran into a problem besides the last one.
After putting the screen back together, customer reported ear speaker not working. I took it out, realigned it, put the flex back in, still nothing. I ended up ordering a flex front camera flex.
I took out the old flex, put in the new flex, and this time, I tried a different technique of inserting the flex connector, similar to the iPhone 6 digitizer flex. If you angle the connector, slightly angled down on the side of the flex cable, and the other side slightly angled up, then press in and connect it, you will get a proper snap in sound. After I turned it on, the ear speaker was working.
For me, i'm not sure if getting a new flex was the answer, or just the connector wasn't being placed down correctly.
On the next 7 Plus that comes in, I am going to test the old flex with my technique, and see if the ear speaker works. I'll report back after some time.
A voté
Annuler
Indice
31 commentaires
I have also same problem earpiece stop working after replaced screen any one fix this problem plz update
Thanks
par saqibmuizz
New front cam. There's fragile IC chips on the front cam flex. It was probably damaged when you took it off the old screen.
par David Brown
We've already tried cam flex, not the issue
par Brandon
any update? I am also having same issue. Tried using new flex cable and new ear piece speaker, does not seem to work at all. Any help would be appreciated.
par PHES16
Having the same issue with a customer. He is the worst, a refrigerator repair guy that thinks a phone is the same a fridge.
par Alfred Sibley
Voir 26 commentaires en plus
