Aller au contenu principal
Pour réparer ensemble - Je crée un compte
L'eMac est un Mac tout-en-un basé sur le G4, conçu pour le marché de l'éducation et commercialisé en avril 2002. C'était le dernier Mac à utiliser un écran CRT. Il était vendu à bas prix aux écoles et à d'autres institutions.
Airport Extreme Card not detected
I have a 800Mhz, 512MB, Mac OS 10.4.11 eMac.
It did not ship with an Airport Extreme card so I have sourced one and attempted to fit it. I put in as normal (above disc drive) and booted the system but it has not been detected. I later tried an Apple Hardware Test and it didn't even find a Card to test.
I know this card works because I put it in my iBook G4 and it worked fine. I then took the card that was in the iBook G4 and tried it in the eMac. Exact same problem. What is wrong with my eMac?
I appreciate any response, thanks!
Répondu ! Afficher la réponse J'ai le même problème
Indice 3
Ajouter un commentaire
4 Réponses
Solution retenue
The reason you are having difficulty installing an Airport Extreme card in your eMac is because the 700/800MHz models use the older Airport card.
You can get one here on iFixit: http://www.ifixit.com/Apple-Parts/Airpor...
Indice 2
1 commentaire:
i must have skipped over that part.... you are correct.
par Partager
Hmmmm?! I have to disagree with the answers here. My reasoning is this:
I have 10 800 MHz eMacs. The standard Airport card WILL NOT fit in them; I just tried it. The slot provided for card installation is slimmer than the Airport Card, and slightly "stepped" on the sides (like an Extreme card).
As to why the card is not registering in your eMac:
Firmware issue
You should double check the devalias and see if the card is listed there. If it is...ouch! If it isn't:
Time to do the old nvram reset, and set defaults. Remember, computers need to be reminded what they are, and what they are supposed to do, once they have been upgraded. That eMac may not know it has the wireless card, because it was never shipped with one, or been intended to have one. The price of buying school surplus.... <sigh>
Give her a good old firmware "slap", and see what she does.
Update
Further proof of my response:
http://support.apple.com/kb/ht3024
eMac ATi and eMac (USb 2.0) both show Extreme supported NOT standard Airport.
Indice 1
You need one of the regular PCMCIA AirPort Cards
Indice 0
1 commentaire:
I voted this down as your answer is redundant. :(
par Partager
My emac does not recognize the airport extreme card I have installed. Help!
emac
PowerMac4, 4
PowerPC G4 (3.3)
1GHz
256 KB
512 MB
133 MHz
4.6.4f1
Indice 0
Ajouter une réponse
QEII Student IT sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 18
Total : 7,328
