Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Modèle début 2011, A1278 / 2.3 GHz i5 ou processeur 2.7 GHz i7.
Questions au sujet de 828 Voir tout
MacBook will not power on when logic board is fitted to chassis
i just received a 2011 mbp13 2.3 i5 model, exhibiting no power whatsoever. not even magsafe when connected.
i pulled the logic board, cleaned thoroughly and added a new DC in board.
testing the new DC in board outside the chassis, i got (at first dim, and then full) green LED at the magsafe. i plugged in the fan, and sure enough the mac was powered on. i pulled the plug, reassembled the laptop, and there's no power whatsoever again.
then, lifting the logic board out while still connected to DCIN, i can power on the laptop. furthermore, i can place the logic board in the chassis and it remains on. if i pull the plug, i cannot restart the mac without removing the logic board.
if i remove, power on, then install the logic board, i can connect the battery and cables and begin to charge. i connected the keyboard, powered off the mac, and the magsafe remains orange. i make all the appropriate connections, and power the mac back on.
everything works, and i'm installing sierra.
the second i remove the magsafe, i'm back to square one and must remove the logic board to power it on again.
whaaaaaaaaat?
Répondu ! View the answer J'ai le même problème
Indice 0
Commentaires:
i have taken my multimeter, and with the logic board and DC-IN board out of the chassis, i cannot locate any shorts between DC-IN and ground.
par
with the logic board installed, i measure ~430ohm between 16.5VDC and any given ground point.
par
Ajouter un commentaire
1 solution
Solution retenue
my known good DCIN board was in fact faulty, shorting 0ohm between 16.5V and GND.
a second known good DCIN board fixed the issue.
Cette réponse a-t-elle été utile ?
Indice 0
Ajouter une réponse
Ronnoc Nailli sera éternellement reconnaissant.
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 49
