Why is the tiller not spinning when the PTO shaft is?
It seams to be the part between the PTO shaft coming from the tractor and the gearbox on the tiller. From the looks of the diagram I found online it looks like the friction clutch assembly is just spinning freely around the shaft that goes into the gearbox on the tiller. Not sure what could be the problem or what part I may need to fix it.
4 commentaires
@rogershepherd post the diagram and a few images on what you are working on with your question. Use this guide Ajout d'images à une question existante for that. we'll need to know what tractor and what tiller. Right now it sounds like the PTO out is okay, just nothing happening on the tiller end. Check for any shear pins and the drive.
par oldturkey03
Usually its just the sheer pin designed to take the torque of a sudden stop in the tiller (like hitting a large rock) and not breaking parts in the tractor or tiller by having the small sheer pin sheering in half...
par Nathanael
Yes .,. This is what I’m thinking is going on with my county line ... thank you ...stay safe and well ... take care brother
par Scott
par Scott
