Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Water is leaking out of the machine
My Coffee machine isn't working properly anymore. The hot water is leaking to the little capsule holder box and the water doesn't touch the coffee capsule.
Is there anyone who could take a look at it?
Update (03/21/2017)
I am located in Palm Beach Gardens, FL 33418
If anyone can recommend me a place where to take to fix it, without paying a fortune, I would appreciate it.
Répondre à cette question J'ai le même problème
Score 2
Commentaires:
I have the same problem too.
par
Ajouter un commentaire
Manta Precision Bit Set
112 embouts pour toute réparation.
Upgrade Your Toolbox
4 solutions
Nespsesso lekt stoom en water, wat moet ik doen?
Cette réponse a-t-elle été utile ?
Maybe you lost a Gasket, I found one with the capsules yesterday and I have the same issue.
I had the same problem with my expresso coffee machine. I opened it and found the water pump tube with an hole in it. I tried to repair it, but could not find any relacement tube with hi pressure capabality.
Same pproblem here. Does anyone know how to fix this ?
Commentaires:
Similar problem. my Inissia is leaking where the rubber hose meets the metal tube. Hot water is leaking out and capsules don't have holes in them. Not sure if leak is caused by pressure build up due to capsule not taking the water or the other way around. Leak causing lack of pressure to puncture the capsule? Any ideas?
par
Ajouter une réponse
NespressoLady sera éternellement reconnaissant.
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 13
30 derniers jours : 401
Total : 12,435
