Aller au contenu principal
Canon's Rebel XT is one of Canon's early entry-level DSLR's. Also marketed as the EOS 350D and the EOS Kiss Digital N.
Questions au sujet de 32 Voir tout
Pop up flash spring replacement
On my EOS Digital xt, I am having a difficult time replacing the spring for the pop up flash. A diagram would be helpful.
Répondre à cette question J'ai le même problème
Indice 2
Ajouter un commentaire
1 solution
Réponse la plus utile
I had the same problem and finally got it fixed last night.
The spring goes in with the slightly longer end with one bend first. This goes in a slot toward the bottom and has to hook around something inside. I put it in with the flash closed but kept checking until I had that end right. To do this I opened the flash while holding the spring until I finally had it so that end of the spring was staying in the slot and not visible. This took several tries. Then I carefully closed the flash while holding the spring and re-attached the top end. For a LONG time I had been trying to just attach this end by turning it counterclockwise and of course it wouldn't stay in the hole. It has to be turned clockwise (going over the top of the spring) and then into it's hole.
I hope my answer is helpful to others with this problem.
Cette réponse a-t-elle été utile ?
Indice 2
Commentaires:
Any chance you have a picture of this? I can't find it online anywhere.
par
thankyou very very much. I had the exact same issues and had been trying endlessly only turning it counterclockwise!
par
Ajouter une réponse
Duane Woodruff sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 4
Total : 825
